[Qgis-developer] forced update on the repo?
Nathan Woodrow madmanwoo at gmail.com
Mon Jan 13 03:07:43 PST 2014
This might help to explain a few things:
http://stackoverflow.com/questions/13177852/why-the-data-of-commits-in-git-log-is-out-of-order
Basically nothing is wrong as the order is not always in the date order
- Nathan
On Mon, Jan 13, 2014 at 8:59 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
>  it seems to affect que pull request now:
> https://github.com/qgis/QGIS/pull/1067
> On 13. 01. 14 10:35, Richard Duivenvoorde wrote:
> On 13-01-14 10:18, Matthias Kuhn wrote:
>  Some general advice (althogh I'm not sure how exactly that happened) is to
> For creating a pull request
> - always start a feature branch from current master
> - if you are coding a feature branch, don't "merge" anything in
> - before you create a pull request do "git fetch origin" and "git rebase
> origin/master" (given origin is the remote for upstream and not your own
> remote, check your .git/config or do "git remote -v | grepgithub.com/qgis")
> - you may do a "git rebase" like in the last line repeatedly without
> doing any damage (as long as the only purpose of your branch is to get
> merged into master)
> - Attention: After a rebase you need to "git push -f". CORE DEVS: IF YOU
> DO THIS ON THE UPSTREAM REPOSITORY YOU WILL BRING CAKE FOR EVERYBODY TO
> THE NEXT HF!
> For merging a pull request
> Option A)
>   - click the merge button (Creates a non-fast-forward merge)
> Option B)
>   - Checkout the pull request (Seehttps://gist.github.com/piscisaureus/3342247)
>   - Test (Also required for option A, obviously)
>   - checkout master, "git merge pr/1234"
>   - Optional: "git pull --rebase": Creates a fast-forward, no "merge
> commit" is made. Cleaner history, but it is harder to revert the merge.
>   - "git push"
> I hope that I got things right and that somebody finds this useful.
>  Hi Matthias,
> I think it is VERY usefull. But I also think we should create a
> 'git'-page in documentation which contains this info.
> I think it would also be helpfull to show the (more general) git
> commands for creating a local branch etc.
> I'll try to create a page for that with the information above, and add
> some stuff that I think is usefull.
> Plz have a look into it when finished.
> Regards,
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140113/76ac708a/attachment.html>
