[Qgis-developer] forced update on the repo?
Matthias Kuhn matthias.kuhn at gmx.ch
Mon Jan 13 06:24:20 PST 2014
>From my understanding: the problem to solve is rather cosmetic?
If yes, -1 to execute this unless there is an option which does not
change checksums.
Matthias
On Mon 13 Jan 2014 03:17:41 PM CET, Radim Blazek wrote:
> Wait a moment the date is wrong as you probably noticed, I have messed
> month with day. I'll post new version soon.
> Radim
> On Mon, Jan 13, 2014 at 3:10 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
>> On Mon, Jan 13, 2014 at 12:59 PM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>>> On 13 January 2014 22:26, Radim Blazek <radim.blazek at gmail.com> wrote:
>>>> Could it be that b4d082f9 and 860e23afc7 have wrong date Jan 12 2013?
>>>> The 860e23afc7 has parent 0c6d9ef90 with Jan 12 2014.
>>> Arghh... you're right. <hangs head in shame> Is there anyway this can
>>> be fixed now? My apologies for the inconvenience this has caused...
>> No problem.
>> It seems to be fixed by:
>> git filter-branch --env-filter 'if [ $GIT_COMMIT =
>> "b4d082f97d82140c55a9b0afee5db06227b9c6b3" ]; then export
>> GIT_AUTHOR_DATE="1417450920+1100"; export
>> GIT_COMMITTER_DATE="1417450920+1100"; fi; if [ $GIT_COMMIT =
>> "860e23afc70b804b7ddc3f2e98f88e7ee5ac995b" ]; then export
>> GIT_AUTHOR_DATE="1417450860+1100"; export
>> GIT_COMMITTER_DATE="1417450860+1100"; fi' 224e34010aa..HEAD
>> Note that checksums of those two commits and all following commits will change.
>> Then you need to be courageous enough to run the very dangerous git
>> push -f. I am not. Please verify everything 10 times before push.
>> Could please someone third try to run the command above and confirm
>> that it corrects the dates and does not do any damage and can be
>> followed by git push --force?
>> I am not git expert.
>> Until we fix that, please do not commit to GitHub and preferably do
>> not comment commits after the problematic commits because checksums
>> will change.
>> Radim
> Qgis-developer mailing list
