[Qgis-developer] QWC first implementation of configurable search results output
Alessandro Pasotti
apasotti at gmail.com
Mon Jan 13 10:18:58 PST 2014
2014/1/13 Andreas Neumann <a.neumann at carto.net>
> Hi,
> >> Thanks for the changes. Do you have an existing test installation
> >> publically available. The GlobalOptions.js contain quite a few different
> >> settings that wouldn't make it compatible with the demo projects in the
> >> main branch. So it is a bit of work to set up your copy at my machine.
> > Not yet sorry, will be probably available in a couple of weeks.
> > My intention was to make all possible configuration parameters optional,
> so
> > that QWC can run with minimal (ideally no) configuration.
> > Your difficulties mean that I've failed :)
> > All new settings I've introduced are tested for
> > typeof('nameofsetting')=='undefined' and shouldn't be mandatory or have
> > smart defaults.
> Well - I did not really try. To be honest. I was just wondering if there
> was an instance already set up that I can test.
> I just saw the italian search configuration (CatastoFabbricatiSearch)
> and assumed that it would not work with the small demo projects we have
> (the hello world and natural earth example).
> If you would put a compatible test project with a spatialite db in the
> projects file I could more easily test the new search system. Even
> better would be if you could enhance the existing projects (e.g. natural
> earth) and provide a working search demo with this project. It would be
> easier to merge with the main branch later on.
Hi, I've set helloworld as default and deleted all my stuff.
There is initial sqlite search support but I had not time to solve the
spatialite PHP support problem (permission denied when loading spatialite
extension from PDO).
You can test the search output options though.
https://github.com/elpaso/QGIS-Web-Client/tree/configurable_layout
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140113/f80ceb8d/attachment.html>
