Hi dev, I discovered the Modeler-only tools : Calculator and I would like to know how to use it. Does anyone have documentation on this specific algorithm ? In the algorithm ui, there is only : 'You can refer to model values in you formula, using single-letter variables, as follows:' Regards, René-Luc D'Hont 3Liz
