[Qgis-developer] New Save as... dialog
Werner Macho
werner.macho at gmail.com
Thu Jan 16 00:57:46 PST 2014
Hi Paolo!
* What do you mean by "lot of empty space in the middle" here is only a
very small stripe
* "mostly emtpy" -> it is filled on demand depending on how many options
are provided by the format. - try to save as SpatiaLite
The only (currently) unfortunate thing is that the More Options button
is not shrinking the window again if you press it again .. So once the
extended options are opened you should leave them switched on.
If anyone has a good idea howto solve it .. suggestions welcome.
The original intention was to make the dialog as small as possible and
not annoy novice users with extended options they might never need. Per
default there should be no need to use the "More Options" button. Every
format should have reasonable defaults now (if not tell me and I am
going to change it).
I am not 100% happy with that layout either but it was the best we
(Matthias and me) could make at that moment.
kind regards
Werner
On 2014-01-15 12:18, Paolo Cavallini wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all.
> I noticed the current dialog for Save as... for vectors should be improved:
> * there is a lot of empty space in the middle
> * the "More Options >>" button is non-standard, as it opens a side block with panels,
> mostly empty
> * IMHO the general appearance should be similar between this dialog and the Save
> as... for rasters.
> Should I open a ticket on this?
> All the best.
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1
> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> iEYEARECAAYFAlLWbqAACgkQ/NedwLUzIr7KdgCggWG368yvvGW4jm7utShg5KHk
> rl8An2ypZmnsbC6sbjpFP1hMLPY18Ho3
> =zC+w
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
