[Qgis-developer] Mmqgis error making a buffer
Geodrinx geodrinx at gmail.com
Fri Jan 17 07:56:38 PST 2014
> What did you input as radius?
I tested with 1000 and with 1000.00 (but any other value has the same effect )
I tested with points and with a line.
The srs was epsg:32632.
But also other srs has the same effect. :(
Is it working to you ?
Roberto
> Greetings,
> André Joost
> Qgis-developer mailing list
