[Qgis-developer] conpiling QGIS in Ubuntu 12.04.4 LTS with Qt Creator 2.4.1
otmane yazidi alaoui
yazidiotmane at gmail.com
Sat Jan 18 14:52:01 PST 2014
hello
i finished the compilation of source with but i want to modify it . to be
able to adapting it with my needs
i tackle another probleme which is the run of this programme with
Qt Creator 2.4.1 Based on Qt 4.8.0 (32 bit)
OS: Ubuntu 12.04.4 LTS
by the way im just a learner a biggener . so excuse me for my simple
questions
2014/1/18 A Huarte <ahuarte47 at yahoo.es>
> Hi, I was who added a reference to this function in order to fix a bug, my
> apologies, It is only supported in gdal 1.10.
> Jürgen E. Fischer solved it using equivalent code.
> my apologies
> Alvaro
> hello friends
> it's been a month since I try to compile the source code of qgis ,
> I continued the installation guide INSTALL file
> but I feel that I have all the different possible problems , it is really
> depressing
> and here are the details
> System compilation : Qt Creator 2.4.1 Based on Qt 4.8.0 (32 bit)
> error obtained :
> / home / alaoui / dev / cpp / QGIS -master / src / core /
> qgscoordinatereferencesystem.cpp : In member function ' bool
> QgsCoordinateReferenceSystem :: axisInverted () const' :
> qgscoordinatereferencesystem.cpp : 407:104 : error : '
> OSREPSGTreatsAsNorthingEasting ' was Not Declared in this scope
> make [2 ] : *** [ src / core / CMakeFiles / qgis_core.dir /
> qgscoordinatereferencesystem.cpp.o ] Error 1
> make [ 1] : *** [ src / core / CMakeFiles / qgis_core.dir / all ] Error 2
> make: *** [all ] Error 2
> 8:07:04 : The process "/ usr / bin / make" ended with code 2 .
> Compilation error of qgis2.1.0 project ( target : Desktop )
> During the execution of step "Make"
> YAZIDI ALAOUI OTMANE
> Ingénieur d'état en Géomatique
> Tel:+212652538743
> @ :yazidiotmane at gmail.com
> http://www.doyoubuzz.com/otmane-yazidi-alaoui
> Qgis-developer mailing list
Tel:+212652538743
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140118/3d66a26e/attachment.html>
