[Qgis-developer] Qgis2threejs suggestions...
Geodrinx geodrinx at gmail.com
Sun Jan 19 07:05:04 PST 2014
Inviato da iPhone
Il giorno 19/gen/2014, alle ore 10:06, Minoru Akagi <akaginch at gmail.com> ha scritto:
> Hi Roberto,
> Is your python webbrowser module overlapped by something? For example,
> you have a plugin named "webbrowser" ? : )
Yes, I created a plugin named "webbrowser" ... :(
So, this is the problem !
> Otherwise, please try to
> set browser path in the setting dialog.
Ok, thank you.  I will inform you.
Regards
Roberto
> Regards,
> Minoru
> 2014/1/18 Geo DrinX <geodrinx at gmail.com>:
>> Hi Minoru ,
>> I taken QGis2threejs now from  repository and I am testing on  MacOSX.
>> I had this:
>> Traceback (most recent call last):
>>  File
>> "/Users/rrr/.qgis2/python/plugins/Qgis2threejs/qgis2threejsdialog.py", line
>> 334, in run
>>    if not tools.openHTMLFile(htmlfilename):
>>  File "/Users/rrr/.qgis2/python/plugins/Qgis2threejs/qgis2threejstools.py",
>> line 128, in openHTMLFile
>>    webbrowser.open(htmlfilename, new=2)    # new=2: new tab if possible
>> AttributeError: 'module' object has no attribute 'open'
>> Versione Python:
>> 2.7.1 (r271:86832, Jun 16 2011, 16:59:05)
>> [GCC 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2335.15.00)]
>> Also on Windows 7  I have the sameā€¦
>> Tell me if you need more info to debug.
>> Roberto
