[Qgis-developer] QGIS web client enable search for Windows users
Marko Markovic gismarko86 at gmail.com
Mon Jan 20 06:28:35 PST 2014
This is my Apache log file:
[Mon Jan 20 12:59:28 2014] [warn] [client 127.0.0.1] (OS 109)The pipe has
been ended.  : mod_fcgid: get overlap result error
[Mon Jan 20 12:59:28 2014] [error] [client 127.0.0.1] Premature end of
script headers: qgis_mapserv.fcgi
On Mon, Jan 20, 2014 at 10:36 AM, Marko Markovic <gismarko86 at gmail.com>wrote:
> First of all thanks for answering! I try to implement search that uses
> existing layers! I try to do this looking at helloworld project, but
> my first problem is that when I try to run helloworld.qgs form default
> projects i cant see map and i am getting an error:
>    1. Resource interpreted as Image but transferred with MIME type
>    text/xml: "
>    http://localhost:91/cgi-bin/qgis_mapserv.fcgi?map=/home/web/qgis-web-client…2548,-7861923.8125477,12082423.812548,15950623.812548&WIDTH=300&HEIGHT=300<http://localhost:91/cgi-bin/qgis_mapserv.fcgi?map=/home/web/qgis-web-client/projects/naturalearth_110million.qgs&LAYERS=Land&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A3857&BBOX=-11730123.812548,-7861923.8125477,12082423.812548,15950623.812548&WIDTH=300&HEIGHT=300>
>    ". OpenLayers.js:494<http://localhost:91/qgisfolder/qgis-web-client-master/site/libs/openlayers/OpenLayers.js>
>    1. GET
>    http://localhost:91/cgi-bin/qgis_mapserv.fcgi?map=/qgisfolder/QGIS-Web-Clie…=-50516615.263158,-13033000,50868915.263158,21121700&WIDTH=1128&HEIGHT=380<http://localhost:91/cgi-bin/qgis_mapserv.fcgi?map=/qgisfolder/QGIS-Web-Client-master/projects/helloworld.qgs&LAYERS=&OPACITIES=&FORMAT=image%2Fpng&TRANSPARENT=TRUE&DPI=96&VERSION=1.3.0&EXCEPTIONS=INIMAGE&SERVICE=WMS&REQUEST=GetMap&STYLES=&CRS=EPSG%3A3857&BBOX=-50516615.263158,-13033000,50868915.263158,21121700&WIDTH=1128&HEIGHT=380>
>    2.
> and this is my URL request
> *http://localhost:91/qgisfolder/qgis-web-client-master/site/qgiswebclient.html?map=/qgisfolder/QGIS-Web-Client-master/projects/helloworld.qgs
> <http://localhost:91/qgisfolder/qgis-web-client-master/site/qgiswebclient.html?map=/qgisfolder/QGIS-Web-Client-master/projects/helloworld.qgs>*
> I have my project named GisParcel.qgis-When I run it form location
> C:\myproject\GisParcel.qgs its work fine. When it work fine URL is:
> C:\myproject\GisParcel.qgs, but when I put it in project folder where is
> helloworld.qgs located
> (C:\OSGeo4W\apache\htdocs\qgisfolder\QGIS-Web-Client-master\projects) it's
> not work and url for this is:
> <http://localhost:91/qgisfolder/qgis-web-client-master/site/qgiswebclient.html?map=>/qgisfolder/QGIS-Web-Client-master/projects/GisParcel.qgs
> And error is:
> XHR finished loading: "*http://localhost:91/cgi-bin/qgis_mapserv.fcgi?map=/qgisfolder/QGIS-Web-Client-master/projects/
> <http://localhost:91/cgi-bin/qgis_mapserv.fcgi?map=/qgisfolder/QGIS-Web-Client-master/projects/>*
> GisParcel
> *.qgs&&_dc=1390210106830&SERVICE=WMS&VERSION=1.3&REQUEST=GetProjectSettings*
> Uncaught TypeError: Cannot read property 'request' of undefined
> QGISExtensions.js:194
> Why my project wont work where i put relative path in url -
> *map=/qgisfolder/QGIS-Web-Client-master/projects/GisParcel.qgs*
> and work with path map=C:\myproject\GisParcel.qgs?
> Why I am getting error when try to open helloworld.qgs project?
> On Sun, Jan 19, 2014 at 1:24 PM, Andreas Neumann <a.neumann at carto.net>wrote:
>> Hi Marco,
>> You will have to provide more details in order that we can help you.
>> Which search method are you trying to implement? There are at least
>> three different methods: the QGIS server based search that uses existing
>> layers within the project, the PostgreSQL/WSGI method, the
>> PostgreSQL/PHP method.
>> What did you do and what does not work?
>> Andreas
>> Am 19.01.2014 12:42, schrieb Marko Markovic:
>> > Hi. Did anybody succeed in enabling search for QGIS web client on
>> Windows
>> > OS?
>> > I follow all steps from Readme on
>> https://github.com/qgis/qgis-web-client!
>> > But my search wont work! Is there a way to do the change of the code so
>> > that i can add my search panel?
>> >  Thanks!
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140120/f22c9e06/attachment.html>
