[Qgis-developer] [Bug] #8298 - CRS change with recently used CRS makes no effect in the first choice
rldhont
rldhont at gmail.com
Mon Jan 20 07:03:07 PST 2014
Hi dev,
Freeze starts on 2014-01-24, I have made a pull-request on the issue
#8298 http://hub.qgis.org/issues/8298
My solution is 5 codes lines, can someone review my code?
Thanks,
René-Luc
Le 10/01/2014 10:46, rldhont a écrit :
> Hi all,
> I made a pull request to fixed the issue #8298
> I implemented the solution to set the default selected CRS in
> projection selector to the last recent.
> You can review my code here :
> https://github.com/qgis/QGIS/pull/1063
> Regards,
> René-Luc D'Hont
> 3Liz
