[Qgis-developer] On the fly simplication of point layers
A Huarte
ahuarte47 at yahoo.es
Mon Jan 20 16:46:21 PST 2014
Ok, I will study it
>If you have time and inclination this would be great (note feature freeze starts in 4 days). A logical starting may be to only return one point per map pixel though I am not sure if you can push that kind of logic over to provider side very easily.
>Regards
>Tim
>>>________________________________
>>> De: Tim Sutton <lists at linfiniti.com>
>>>Para: A Huarte <ahuarte47 at yahoo.es>
>>>CC: qgis-developer <qgis-developer at lists.osgeo.org>
>>>Enviado: Lunes 20 de enero de 2014 22:57
>>>Asunto: Re: [Qgis-developer] On the fly simplication of point layers
>>>Hi
>>>On Mon, Jan 20, 2014 at 11:47 PM, A Huarte <ahuarte47 at yahoo.es> wrote:
>>>done:
>>>>https://github.com/qgis/QGIS/pull/1093
>>>>This patch hides the simplification rendering tab for point layers, now it is not supported (internally I am not trying to simplify point layers). Thanks Tim!
>>>>About if there is a use case for point simplification, I know one, (gvSIG + dielmo open lidar) use it for load extreme big point layers as LiDAR LAS files are.
>>>>It know the code in java and I think easy migrate to QGIS. Basically, It ignore points by distance in a similar style as the current simplifier classes.
>>>Sorry I see my original email was not very clear - I meant if there was a use case for point simplification as *currently implemented in master* - I fully agree that filtering proximal points would be a good performance booster, as would providing a point clustering capability.
>>>>If you think good for QGIS I think but I can imlement it
>>>That would be great! Thanks for your pull request.
>>>Regards
>>>Tim
>>>>Alvaro
>>>>>Para: qgis-developer <qgis-developer at lists.osgeo.org>
>>>>>Enviado: Lunes 20 de enero de 2014 21:29
>>>>>Asunto: [Qgis-developer] On the fly simplication of point layers
>>>>>Ok I guess you can see where I am going to go with this email :-) Is there any point to allowing users to simplify point layers? Alvaro, can your remove the point rendering tab in layer properties (and I guess check internally that you are not trying to simplify point layers)? Or is there a use case for point simplification that I am not getting?
>>>>>Regards
>>>>>Tim
>>>>>Tim Sutton - QGIS Project Steering Committee Member
>>>>>Please do not email me off-list with technical
>>>>>support questions. Using the lists will gain
>>>>>more exposure for your issues and the knowledge
>>>>>surrounding your issue will be shared with all.
>>>>>Irc: timlinux on #qgis at freenode.net
>>>>>_______________________________________________
>>>>>Qgis-developer mailing list
>>>>>Qgis-developer at lists.osgeo.org
>>>>>http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140121/8f191ee3/attachment.html>
