[Qgis-developer] Qgis2threejs suggestions...
Minoru Akagi akaginch at gmail.com
Mon Jan 20 22:38:07 PST 2014
2014/1/21 Geodrinx <geodrinx at gmail.com>:
>>>  if there are more than one  DTM_  layers, it could be
>>> possible to have together clipped in the output ?   Or, only one is possible
>>> to have ?
>> Only one. You should merge DTM files into one in advance or make use
>> of vrt file.
> If I well understand from documentation, a .vrt file is an xml index of many raster files.
> It is correct ?
> And QGis supports it, true ?
> I will try it as soon as possible :)
Yes, works fine.
Cheers,
Minoru
