[Qgis-developer] Print composer and constrained line elements
Andreas Neumann a.neumann at carto.net
Fri Jan 24 04:39:44 PST 2014
I know it is already feature freeze - but what I am still missing in the
print composer - is the ability to constrain a line to be horizontal or
vertical. In Inkscape you do this with the ctrl-key, which limits it to
15 or 30 degree steps. In QGIS we have something similar with the point
rotation which you can restrict to these steps.
And maybe the "arrow" should be renamed to "line" and the arrowhead
should be an option, not the default.
I often need lines in my layouts, but not so often arrows.
What do you think?
I could also wait for QGIS 2.4 of course ... I will be patient.
Andreas
