[Qgis-developer] QGIS testing via ubuntugis and GDAL
Jeremy Palmer
JPalmer at linz.govt.nz
Sun Jan 26 15:52:41 PST 2014
>> Apparently it was that way since jan 9th, but for precise it's not true anymore
>> - and the others should follow with the next (successful) nightly build. Lets
>> see if the sip updates work everywhere...
Thanks Jürgen, it's built against gdal 1.10 now :)
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
