[Qgis-developer] [Blocker?] Data defined labels not working with if X, Y filed values are NULL
Alexandre Neto
senhor.neto at gmail.com
Mon Jan 27 04:08:45 PST 2014
I made some tests and this is only happening with postgis tables. It seams
to me that labels are being rendered around 0,0 coordinates.
This worked well in 2.0.1, possible blocker?
I'm using QGIS master 64bit in windows 7 64bit
Best regards,
Alexandre Neto
On Thu, Jan 23, 2014 at 2:24 PM, Alexandre Neto <senhor.neto at gmail.com>wrote:
> Hello all,
> In 2.0.1, NULL values in X and Y fields for data defined labels were
> ignored and the label would print in the default place.
> Testing QGIS 2.1.0, I have noticed that label would not print in the same
> conditions.
> Is this the expected behavior?
> This issue might be related: http://hub.qgis.org/issues/9148 but the
> proposed workaround does not seem very logic to me.
> Thanks,
> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140127/69e91b40/attachment-0001.html>
