[Qgis-developer] QGIS and 3D
gene martin.laloux at gmail.com
Mon Jan 27 09:14:55 PST 2014
Among others:
 In French:
-  PyQGIS (QGIS 2): les coupes géologiques (colorisation d'un profil
topographique élaboré à partir d'un MNT en fonction des couleurs d'un raster
et placement des points d'intersection avec les limites des couches
géologiques)
<http://www.portailsig.org/content/pyqgis-qgis-2-les-coupes-geologiques-colorisation-d-un-profil-topographique-elabore-partir-d>
(PyQGIS (QGIS 2) geological cross-sections ("colorization" of a topographic
profile with the colors of a geological map and placement of the points of
intersection with the boundaries of geological layers)).
In Spanish:
-  QGIS, visualización 3D de capas vectoriales con Python
<http://geotux.tuxfamily.org/index.php/en/geo-blogs/item/315-qgis-visualizacion-3d-de-capas-vectoriales-con-python>
but also in this list, for example:
-  visualizing 3D data (Z values) or data with z attribute: a solution
<http://osgeo-org.1560.x6.nabble.com/visualizing-3D-data-Z-values-or-data-with-z-attribute-a-solution-td5005360.html>
-  For geologists: 3D geological boreholes
<http://osgeo-org.1560.x6.nabble.com/For-geologists-3D-geological-boreholes-td5007085.html>
and in GIS Stack Exchange, for example:
-  TIN Interpolation using a vector layer
<http://gis.stackexchange.com/questions/41891/tin-interpolation-using-a-vector-layer/41922#41922>
-  Create cross section with polygon intersects in QGIS
<http://gis.stackexchange.com/questions/83605/create-cross-section-with-polygon-intersects-in-qgis/83619#83619>
- with only Python:
-  Display a georeferenced DEM surface in 3D matplotlib
<http://gis.stackexchange.com/questions/66367/display-a-georeferenced-dem-surface-in-3d-matplotlib/66440#66440>
View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-and-3D-tp5099845p5100283.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
