[Qgis-developer] Consistency in adding layers (especially OGC)
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Jan 28 02:57:26 PST 2014
Hi Nathan,
Unfortunately my talent lies with finding flaws and suggesting
tweaks/improvements to things rather than designing UI's. I'm more than
happy to offer feedback.
Is there any way to spur this along? We have a limited amount of commercial
support (we're a local authority going through "austerity measures"-
budgets dwindling); this would be good to see in 2.4 if possible.
Cheers,
Jonathan
On 28 January 2014 10:39, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey Jonathan,
> Yes this is a bit of a known issue.  It has always been a goal of mine to
> try and tackle the issue of refactoring the whole lot into single dialog.
>  I have some early dialog mockups floating around that you might be able to
> find, although I would tweak it a bit now.
> If you have some ideas for a new single UI it would be good to have a
> look, or even if you just have ideas on what you want to see.
> - Nathan
> On Tue, Jan 28, 2014 at 8:03 PM, Jonathan Moules <
> jonathanmoules at warwickshire.gov.uk> wrote:
>> Hi List,
>> This may be too late for 2.2 (some are features), but something that's
>> bugging me no end is the complete lack of consistency between all the
>> dialogs for the OGC services. Below I've created a somewhat exhaustive list
>> of differences-that-shouldn't-be between the way they behave - mostly the
>> add-layer dialog.
>> However, rather than rectify the issues, would it maybe make more sense
>> to just create a single new dialog from scratch and use that instead?
>> Ideally for all formats, but if necessary, just the OGC stuff.
>>   What are the plans relating to add-layer dialogs? Is there a preferred
>> option? Or will/desire to create a universal dialog for adding layers?
>> Cheers,
>> Jonathan
>> *Adding Layers:*
>> Add/Close buttons
>> For WCS these are the wrong way around!
>> Layer Title|Name:
>> - For WMS, WCS - use the layer Title rather than the layer Name when
>> adding to the layers list (WFS & WMTS already do this).
>>  - Either add "Use title for layer name" checkbox to WMS/WMTS, WCS, or
>> remove from WFS.
>> - WMS seems to allow you to fill in a "Layer name" - add to other
>> dialogs? If so, make it more obvious what it does.
>> Filter:
>> Add Filter function for WMS, WMTS, WCS (already exists for WFS).
>> Differentiate windows:
>> http://hub.qgis.org/issues/9193
>> Tabs:
>> WCS: Remove "Layers" tab as pointless.
>> WMS/WMTS - I have no idea what "Server Search" or "Layer order" do -
>> never seen them active.
>> CRS:
>> All - Make CRS section same between dialogs.
>> WMS - why is "Tile Size" and "Feature limit for GetFeatureInfo" inside
>> the CRS box?
>> Format:
>> WCS or WMS/WMTS - Use same method for selecting format. One uses dropdown
>> (WCS), one uses checkboxes. I guess WFS doesn't need this option.
>> Column list:
>> All - In list of layers, use same order of columns and same selection of
>> columns.
>> WCS, WMS - Column widths autodetected. (Already done for WMTS, WFS)
>> Caching:
>> WCS / WFS - Offer same method for choosing caching settings.
>> Add Layer:
>> WFS - Don't close the dialog. Or Do close it for WMS/WMTS and WCS.
>> *Create Connection*:
>> WMS/WMTS - says "Create a new WMS connection" - should say WMTS too.
>>  WCS/WFS - Referer option (in WMS already)
>> WFS - "Connection details" not in bold (is on WMS/WCS)
>> *Metadata*:
>> Following on from this ticket - http://hub.qgis.org/issues/8870 -
>> suggested changes to layer properties -> Metadata:
>> WMS, WMTS and WCS:
>>  - Don't list entire Get Capabilities in properties, only the section for
>> that particular layer. WFS already does this.
>>  - All OGC Services - Populate the Description/attribution/metadataURL
>> from the GetCapabilities.
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140128/4e57e6ee/attachment-0001.html>
