[Qgis-developer] Enable snapping on intersections
Paolo Cavallini
cavallini at faunalia.it
Fri Jan 31 08:23:45 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 31/01/2014 15:46, Jakob Lanstorp ha scritto:
> Snap to intersection makes you snap to just that intersection point. Did a
> test with two polygon layers and a point layer. Adding a point to the point
> layer, while within the snap tolerance, made the point appear right on the
> intersection between the two polygon layers. Removing the 'Enable snapping
> on intersection' made the point not snap to the intersection.
> I have set snapping settings to both polygon layers, prehaps you missed that
> in the snap options.
Hi Jakob,
I tried as you described, in various combinations, but could not see a difference
between activating and deactivating the option.
All the best, and thanks.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlLrzhEACgkQ/NedwLUzIr7IvACguomLoiYG/ZVTZqkgjZ3vYFWp
rdQAn3CN9twILYCuLwo/FJjloZ0IkTDt
=ILCh
-----END PGP SIGNATURE-----
