[Qgis-developer] Do we need a single select map tool?
Nathan Woodrow madmanwoo at gmail.com
Tue Jul 1 04:54:57 PDT 2014
Hey,
I would like to propose that we remove the single select map tool.
Main reason to remove is its function is redundant as the rectangle select
does a single point select if you don't drag i.e single click.  I live in
rectangle select mode 99% of the time and never have any issues.
As the rectangle select can already do both actions I don't really see the
need to keep both tools when one would suffice.
Thoughts?
- Nathan
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140701/2288f1d6/attachment.html>
