[Qgis-developer] error creating QGIS package with creatensis
Jürgen E. Fischer
jef at norbit.de
Wed Jul 2 03:28:51 PDT 2014
Hi Matteo,
On Wed, 02. Jul 2014 at 12:11:42 +0200, matteo wrote:
> well in "packages-x86_64" I found "gdal-sosi-4.0-1.tar.bz2". The same
> package is in "packages-x86", but I didn't have any problem with x86.
Check if the setup.ini is up-to-date. You should have gdal-sosi-4.0-2.tar.bz2
> Can I avoid to include this package in the building process?
Only by specifying the dependencies of qgis-full leaving out gdal-sosi on the
command line (instead of qgis-full or nothing as that it's the default).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS PSC member (RM) Germany IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
