[Qgis-developer] Navigation toolbar
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Jul 2 04:19:39 PDT 2014
Hi Andreas,
On 2 July 2014 08:40, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> In addition to the discussion around the selection tool I would like to
> discuss a reduction of buttons in the navigation toolbar. I think it eats
> way too much screen-space by default. I'd like to suggest the following:
> 1. get rid of the refresh button. I never use it. If you have to use it,
> than it is a bug in the software.
-1 = Alas there are bugs in QGIS, I do have to use it fairly frequently.
More than many on that toolbar actually.
> 2. Potentially remove the "Zoom to Layer" button. It is available in the
> context menu of the layer and in the "View" menu, should you need it.
3. Potentially remove the "Zoom to native resolution button". I think it is
> good enough if this functionality is available in the "View" menu. Do
> people really use this function? Maybe with raster layers?
+1 Never used it "native resolution" myself from the nav bar. Always right
click on a layer - that would probably be the most logical place to leave
both functions/
4. Potentially combine the touch zoom/and pan tool with the pan tool into a
> single tool. Is there a specific reason why both of these tools are
> available? Doesn't the "Touch zoom and pan" also support pan with the mouse?
+1 I've never been clear what the difference between them is anyway.
> 5. Potentially combine the pan to selected and zoom to selected into a
> drop-down button menu, like we have with the measure or select tool.
+1 seems sensible.
Just my 2p.
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain confidential, sensitive or personal information and should be
handled accordingly. Unless you are the named addressee (or authorised to
receive it for the addressee) you may not copy or use it, or disclose it to
anyone else. If you have received this transmission in error please notify
the sender immediately. All email traffic sent to or from us, including
without limitation all GCSX traffic, may be subject to recording and/or
monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140702/c9df50b1/attachment.html>
