[Qgis-developer] How do QGIS plugin unit test?
BJ Jang
qgis.tr.kr at gmail.com
Wed Jul 2 18:54:49 PDT 2014
Dear all.
I want make a QGIS Python plugin with unit test using the 'Plugin Builder'
The 'Plugin Builder' make some unit test class automatically in test folder
like as test_init.py, test_translations.py.
I want to do unit test by these class but I had failed.
This is my unit test code.
> import unittest
> import MyPlugin
> from MyPlugin.test.test_init import TestInit
> suite = unittest.TestLoader().loadTestsFromTestCase(TestInit)
> unittest.TextTestRunner(verbosity=2).run(suite)
But, execute results is like this.
> Traceback (most recent call last):
> File "<input>", line 1, in <module>
> File "C:/Temp/qgisPluginUnitTest.py", line 4, in <module>
> File "C:\PROGRA~1\QGISVA~1\apps\Python27\lib\unittest\runner.py", line
> 151, in run
> test(result)
> File "C:\PROGRA~1\QGISVA~1\apps\Python27\lib\unittest\suite.py", line
> 70, in __call__
> return self.run(*args, **kwds)
> 108, in run
> test(result)
> File "C:\PROGRA~1\QGISVA~1\apps\Python27\lib\unittest\case.py", line
> 395, in __call__
> 306, in run
> result.startTest(self)
> 55, in startTest
> self.stream.flush()
> IOError: [Errno 9] Bad file descriptor
> execfile(u'C:/Temp/qgisPluginUnitTest.py'.encode('mbcs'))
> File "C:/Temp/qgisPluginUnitTest.py", line 5, in <module>
> 151, in run
> test(result)
> 70, in __call__
> 108, in run
> test(result)
> 395, in __call__
> 306, in run
> 55, in startTest
> self.stream.flush()
This is a source code of test_init.py
> # coding=utf-8
> """Tests QGIS plugin init."""
> __author__ = 'Tim Sutton <tim at linfiniti.com>'
> __revision__ = '$Format:%H$'
> __date__ = '17/10/2010'
> __license__ = "GPL"
> __copyright__ = 'Copyright 2012, Australia Indonesia Facility for '
> __copyright__ += 'Disaster Reduction'
> import os
> import unittest
> import logging
> import ConfigParser
> LOGGER = logging.getLogger('QGIS')
> class TestInit(unittest.TestCase):
> """Test that the plugin init is usable for QGIS.
> Based heavily on the validator class by Alessandro
> Passoti available here:
> http://github.com/qgis/qgis-django/blob/master/qgis-app/
> plugins/validator.py
> def test_read_init(self):
> """Test that the plugin __init__ will validate on plugins.qgis.org
> # You should update this list according to the latest in
> # https://github.com/qgis/qgis-django/blob/master/qgis-app/
> # plugins/validator.py
> required_metadata = [
> 'name',
> 'description',
> 'version',
> 'qgisMinimumVersion',
> 'email',
> 'author']
> file_path = os.path.abspath(os.path.join(
> os.path.dirname(__file__), os.pardir,
> 'metadata.txt'))
> LOGGER.info(file_path)
> metadata = []
> parser = ConfigParser.ConfigParser()
> parser.optionxform = str
> parser.read(file_path)
> message = 'Cannot find a section named "general" in %s' % file_path
> assert parser.has_section('general'), message
> metadata.extend(parser.items('general'))
> for expectation in required_metadata:
> message = ('Cannot find metadata "%s" in metadata source
> (%s).' % (
> expectation, file_path))
> self.assertIn(expectation, dict(metadata), message)
> if __name__ == '__main__':
> unittest.main()
Please let me know what is wrong.
Regards,
BJ Jang.
Open Source GIS Technical Manager / e-Cartographer
BJ Jang
*Gaia3D Inc,*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140703/6855eedf/attachment.html>
