[Qgis-developer] SOSI support in QGIS
Stott, James
fmrojst at fylkesmannen.no
Sun Jul 6 04:49:53 PDT 2014
Just to double check a couple of things, 1) you need to install the gdal-sosi package using the OSGeo4W installer. 2) You will need to update all packages using the OSGeo4W installer as the changes Jürgen has made seem to have been made today.
If you go into QGIS and select Add Vector Layer from the Layer menu (these instructions assume an English GUI, obviously if you are using the Norwegian translated GUI it will be in Norwegian).
Here you need to make sure Source type is set to File.
Click browse.
In the bottom right hand corner of the open file dialog, you will see a drop down menu.
Here you should find an option for SOSI.
Select a SOSI file and select and click open.
Click Open
A dialog will appear allowing you to select which layers from the SOSI file to open. Choose the ones you want and select OK.
QGIS will load the data.
Hope this helps.
James
________________________________________
From: qgis-developer-bounces at lists.osgeo.org [qgis-developer-bounces at lists.osgeo.org] on behalf of klausenlie [klausenlie at online.no]
Sent: 06 July 2014 13:37
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] SOSI support in QGIS
Hi James!
Can you please tell me where you are in QGIS now?
I haven`t found what you talk about here.
Tommy
View this message in context: http://osgeo-org.1560.x6.nabble.com/SOSI-support-in-QGIS-tp5148046p5149826.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
