[Qgis-developer] Openlayers plugin support in QGIS 2.4
René-Luc Dhont
rldhont at gmail.com
Sun Jul 6 23:53:23 PDT 2014
Hi Ali,
You can use this method instead of OpenLayers Plugin :
Using Map Tile Servers in QGIS 2.4
http://www.konstantingreger.net/using-map-tile-servers-in-qgis-2-4/
Based on :
How to display OpenStreetMap data tiles with no plugin inside Qgis
http://www.3liz.com/blog/rldhont/index.php?post/2012/07/17/OpenStreetMap-Tiles-in-QGIS
Regards,
René-Luc D'Hont
Le 07/07/2014 07:38, Aamir Ali a écrit :
> Dear All
> I am using QGIS 2.4 built using qgis source code and qt creator in
> ubuntu. I am unable to find openlayers plugin in the list of plugin
> repository. I have a two questions
> 1. Whether it is not compatible with this version or my build has some problems?
> 2. If its not compatible then how long it will take the community to
> release the compatible version?
> Aamir Ali
> Qgis-developer mailing list
