[Qgis-developer] Openlayers plugin support in QGIS 2.4
Etienne Tourigny etourigny.dev at gmail.com
Mon Jul 7 09:13:31 PDT 2014
You cannot use the google maps TMS "service", it is not allowed under the
Google Maps TOS.
On Mon, Jul 7, 2014 at 4:54 AM, René-Luc Dhont <rldhont at gmail.com> wrote:
> Hi Ali,
> You'll find examples here :
> http://www.gdal.org/frmt_wms.html
> Remember that using Google Maps needs to accept the Google licence.
> Regards
> René-Luc
> Le 07/07/2014 09:42, Aamir Ali a écrit :
>> Thanks for your prompt response
>> I need to call google maps, how can I use TMS service to call the
>> tiles from Google Map.
>> Regards
>> Ali
>> On Mon, Jul 7, 2014 at 11:53 AM, René-Luc Dhont <rldhont at gmail.com>
>> wrote:
>>> Hi Ali,
>>> You can use this method instead of OpenLayers Plugin :
>>> Using Map Tile Servers in QGIS 2.4
>>> http://www.konstantingreger.net/using-map-tile-servers-in-qgis-2-4/
>>> Based on :
>>> How to display OpenStreetMap data tiles with no plugin inside Qgis
>>> http://www.3liz.com/blog/rldhont/index.php?post/2012/
>>> 07/17/OpenStreetMap-Tiles-in-QGIS
>>> Regards,
>>> René-Luc D'Hont
>>> Le 07/07/2014 07:38, Aamir Ali a écrit :
>>>> Dear All
>>>> I am using QGIS 2.4 built using qgis source code and qt creator in
>>>> ubuntu. I am unable to find openlayers plugin in the list of plugin
>>>> repository. I have a two questions
>>>> 1. Whether it is not compatible with this version or my build has some
>>>> problems?
>>>> 2. If its not compatible then how long it will take the community to
>>>> release the compatible version?
>>>> Aamir Ali
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140707/f00ef431/attachment.html>
