[Qgis-developer] Virtual fields or auto-update trigger?
Andreas Neumann a.neumann at carto.net
Tue Jul 8 02:00:05 PDT 2014
I haven't yet tested it.
Would it automatically update if data in other widgets change without
having to press the save button first or having to close/open the form?
Thanks,
Andreas
Am 08.07.2014 08:42, schrieb Nathan Woodrow:
> Hey Andreas,
> You mean this https://github.com/qgis/QGIS/pull/1494 ;)
> - Nathan
> On Tue, Jul 8, 2014 at 6:41 PM, Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
>     Hi,
>     Is someone working on "virtual fields" or auto-update triggers where a
>     field value would update after the feature was created, with a QGIS
>     expression?
>     Main use-case would be field widgets in forms where one wants to display
>     derived data.
>     This has been discussed several times, but it something in the works?
>     Thanks,
>     Andreas
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/qgis-developer
