[Qgis-developer] Fwd: [Qgis-user] Simplified interface - toolbox
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Mon Jul 21 07:01:59 PDT 2014
Hi List,
Further to this, has a new build of QGIS been created/released that has
this issue resolved? I note the version number is now 2.4.0.1.
Thanks,
Jonathan
On 10 July 2014 00:24, Victor Olaya <volayaf at gmail.com> wrote:
> The issue is actually a packaging issue. There was a problem in the
> cmake.txt file, and it is not copying the file that is used to classify the
> algorithm in categories in the simplified interface.
> The problem should be fixed now, and I guess that we will release a new
> version in the following days, which will include this fix and the new
> modeler
> You can manually fix it by adding the missing file in the gui folder under
> the processing folder. In a OSGEO4W installation, that would
> be C:\OSGeo4W64\apps\qgis\python\plugins\processing\gui
> The file can be found here:
> https://raw.githubusercontent.com/qgis/QGIS/master/python/plugins/processing/gui/algclasssification.txt
> Thanks for your help
> 2014-07-09 14:03 GMT+02:00 Jonathan Moules <
> jonathanmoules at warwickshire.gov.uk>:
> Ok,
>> I've reported it to the tracker:
>> https://hub.qgis.org/issues/10854
>> Seems like quite a bad bug from a user-interface perspective.
>> Thanks,
>> Jonathan
>> On 9 July 2014 12:33, Randal Hale <rjhale at northrivergeographic.com>
>> wrote:
>>> Same Bug on Ubuntu 12.04 using ubuntuGIS Repository
>>> On 07/09/2014 07:28 AM, Victor Olaya wrote:
>>> No, it sounds like a bug, and someone else reported that to me yesterday
>>> as well. It doens't happen in all installations of QGIS apparently. I will
>>> try to work on that at the end of the day today.
>>> Thanks for your help!
>>> 2014-07-09 12:44 GMT+02:00 Jonathan Moules <
>>>> Hi List,
>>>> Using 2.4 I've noticed that on the "simplified toolbox" there aren't
>>>> actually any tools any more.
>>>> There are only Models and Scripts (neither of which is simple. And
>>>> also "recently used", although that requires the user to have found the
>>>> advanced interface.
>>>> Is this intentional? I guess not given it seems pointless to have a
>>>> "simplified interface" for a toolbox that has no tools.
>>>> Cheers,
>>>> Jonathan
>>>> This transmission is intended for the named addressee(s) only and may
>>>> contain confidential, sensitive or personal information and should be
>>>> handled accordingly. Unless you are the named addressee (or authorised to
>>>> receive it for the addressee) you may not copy or use it, or disclose it to
>>>> anyone else. If you have received this transmission in error please notify
>>>> the sender immediately. All email traffic sent to or from us, including
>>>> without limitation all GCSX traffic, may be subject to recording and/or
>>>> monitoring in accordance with relevant legislation.
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Randal Hale
>>> North River Geographic Systems, Inchttp://www.northrivergeographic.com423.653.3611 rjhale at northrivergeographic.com
>>> twitter:rjhalehttp://about.me/rjhale
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140721/dd568a71/attachment.html>
