[Qgis-developer] compile error
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Tue Jul 22 02:30:52 PDT 2014
Yes, checkout this morning.
Stefan
Von: Nathan Woodrow [mailto:madmanwoo at gmail.com]
Gesendet: Dienstag, 22. Juli 2014 11:28
An: Jorge Tornero - Listas
Cc: qgis-developer at lists.osgeo.org; Ziegler Stefan
Betreff: Re: [Qgis-developer] compile error
Are you on the latest code? This build error was fixed last night.
On Jul 22, 2014 7:27 PM, "Jorge Tornero - Listas" <jtorlistas at gmail.com<mailto:jtorlistas at gmail.com>> wrote:
Hello all,
Same happened to me some minutes ago. A second run of make just make it compile (I dindn't do nothing, don't ask :) ). I'm on Kubuntu 14.04.
Anyway, I get an error (posted yesterday) when running the compiled source:
Couldn't load PyQGIS.
Python support will be disabled.
  File "", line 1, in
  File "/home/antares/dev/QGIS/build/output/python/qgis/gui/__init__.py", line 1, in
    from qgis._gui import *
ImportError: dynamic module does not define init function (init_gui)
Python version:
2.7.6 (default, Mar 22 2014, 23:03:41)
[GCC 4.8.2]
QGIS version:
2.5.0-Master 'Master', 8f0b898
Don't have any clue about that. I've found and issue in the hub:
https://hub.qgis.org/issues/10218
But it doesn't say much about how to solve (just fixed problem)
Maybe it is matter of a ticket?
Best regards
El 22/07/14 11:02, Ziegler Stefan escribió:
Hi
I get an compile error on master:
[ 98%] Building CXX object python/CMakeFiles/python_module_qgis__analysis.dir/analysis/sip_analysispart3.cpp.o
Linking CXX shared library ../output/python/qgis/_analysis.so
[ 98%] Built target python_module_qgis__analysis
[ 98%] Built target pyanalysis
[ 98%] Generating core/sip_corepart0.cpp, core/sip_corepart1.cpp, core/sip_corepart2.cpp, core/sip_corepart3.cpp
Scanning dependencies of target python_module_qgis__core
[ 98%] Building CXX object python/CMakeFiles/python_module_qgis__core.dir/core/sip_corepart0.cpp.o
[ 98%] Building CXX object python/CMakeFiles/python_module_qgis__core.dir/core/sip_corepart1.cpp.o
[ 98%] Building CXX object python/CMakeFiles/python_module_qgis__core.dir/core/sip_corepart2.cpp.o
[ 98%] Building CXX object python/CMakeFiles/python_module_qgis__core.dir/core/sip_corepart3.cpp.o
Linking CXX shared library ../output/python/qgis/_core.so
[ 98%] Built target python_module_qgis__core
[ 98%] Built target pycore
[ 98%] Generating gui/sip_guipart0.cpp, gui/sip_guipart1.cpp, gui/sip_guipart2.cpp, gui/sip_guipart3.cpp
sip: Unable to find file "Qsci/qscimod4.sip"
make[2]: *** [python/gui/sip_guipart0.cpp] Error 1
make[1]: *** [python/CMakeFiles/python_module_qgis__gui.dir/all] Error 2
make: *** [all] Error 2
I'm on Ubuntu 14.04.
Regards
Stefan
Freundliche Grüsse
Stefan Ziegler
Kantonsgeometer
Amt für Geoinformation
Amtliche Vermessung
Rötistrasse 4
4500 Solothurn
Telefon +41 32 627 75 96<tel:%2B41%2032%20627%2075%2096>
Telefax +41 32 627 75 98<tel:%2B41%2032%20627%2075%2098>
stefan.ziegler at bd.so.ch<mailto:stefan.ziegler at bd.so.ch>
http://www.so.ch
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140722/33f92329/attachment.html>
