[Qgis-developer] Processing subplugins broken on master?
Alexander Bruy
alexander.bruy at gmail.com
Fri Jul 25 07:40:48 PDT 2014
Hi Paolo,
seems this is result of the huge refactoring of inputs and outputs.
Now all inputs are in processing.core.parameters and all outputs in
processing.core.outputs packages.
So fixing this is trivial task, just adjust import clauses
2014-07-25 16:32 GMT+03:00 Paolo Cavallini <cavallini at faunalia.it>:
> Hi all.
> On current master, with upgraded Processing plugin, its subplugins fail:
> Lecos
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 454, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> ImportError: No module named outputs.OutputVector
> sextante_animove
> File "/home/paolo/.qgis2/python/plugins/sextante_animove/mcp.py", line 8, in
> from processing.parameters.ParameterVector import ParameterVector
> ImportError: No module named parameters.ParameterVector
> processinglwgeomprovider
> File
> "/home/paolo/.qgis2/python/plugins/processinglwgeomprovider/LwgeomAlgorithm.py", line
> 26, in
> from processing.outputs.OutputVector import OutputVector
> Looks an easy fix, perhaps better if Processing devs give a hint to plugin developers?
> Thanks.
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
Alexander Bruy
