[Qgis-developer] Processing subplugins broken on master?
Nathan Woodrow
madmanwoo at gmail.com
Fri Jul 25 15:33:24 PDT 2014
We need to be careful because now processing is core it is really part of
the API and we really shouldnt be breaking that. As such I think you should
just redirect the module so old code still works.
You can just do something like this in __init__.py for processing
Import processing.core.output
Output = processing.core.output
So when you import processing and call output it really calls the new
submodule.
Nathan
On Jul 26, 2014 3:04 AM, "Victor Olaya" <volayaf at gmail.com> wrote:
> Yes, it is supposed to stay. The refactoring was made to have a more
> consistent structure, so we should keep it like that.
> Let me know if you need help with that, although, as Alex say, it
> shouldn't be too difficult to adapt
> 2014-07-25 16:48 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
>> Il 25/07/2014 16:40, Alexander Bruy ha scritto:
>> > seems this is result of the huge refactoring of inputs and outputs.
>> > Now all inputs are in processing.core.parameters and all outputs in
>> > processing.core.outputs packages.
>> > So fixing this is trivial task, just adjust import clauses
>> Yes, that's what I understood. Will this syntax stay? If so, I can open
>> relevant
>> tickets, possibly PRs, on the involved plugins.
>> Thanks.
>> Paolo Cavallini - www.faunalia.eu
>> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140726/2ae94d01/attachment.html>
