[Qgis-developer] [GRASS-dev] GRASS & QGIS: the future
Markus Neteler neteler at osgeo.org
Mon Jul 28 15:26:35 PDT 2014
On Fri, May 30, 2014 at 12:38 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Radim Blazek wrote:
>> > Can you try the attached patch? The new function should be used like:
>> >         if (setjmp(*G_fatal_longjmp(1))) {
>> >             // this will be executed on fatal errors
>> Works. Can I hope the patch will find a way to 7.0.0?
> Committed in r60590.
Glynn, should I backport that to relbranch70?
Markus
