[Qgis-developer] Processing subplugins broken on master?
Luigi Pirelli luipir at gmail.com
Tue Jul 29 03:29:59 PDT 2014
Hi victor something is changed in the help file managing.
for the lwgeom the provider helpFile funcion is no more used and a
./help/<lowercase algorithm name>.rst is loaded
it could be ok, but for some help it's very difficult to convert from
html to rst... and loading rst with embedded images is really slow!
Why not leaving the use of helpFile in html?
lt me know how to allow algorithm help working again, I can try figure
out a patch to do this, but porbably is unuseful if you're doing a
refactoring
regards,
Luigi Pirelli (luigi.pirelli at faunalia.it - luipir at gmail.com)
On 25 July 2014 19:04, Victor Olaya <volayaf at gmail.com> wrote:
> Yes, it is supposed to stay. The refactoring was made to have a more
> consistent structure, so we should keep it like that.
> Let me know if you need help with that, although, as Alex say, it shouldn't
> be too difficult to adapt
> 2014-07-25 16:48 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
>> Il 25/07/2014 16:40, Alexander Bruy ha scritto:
>> > seems this is result of the huge refactoring of inputs and outputs.
>> > Now all inputs are in processing.core.parameters and all outputs in
>> > processing.core.outputs packages.
>> > So fixing this is trivial task, just adjust import clauses
>> Yes, that's what I understood. Will this syntax stay? If so, I can open
>> relevant
>> tickets, possibly PRs, on the involved plugins.
>> Thanks.
>> Paolo Cavallini - www.faunalia.eu
>> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
