[Qgis-developer] Implemented break lines on intersections option during line layers editing
G. Allegri
giohappy at gmail.com
Mon Jun 2 09:48:37 PDT 2014
I was out for holidays.
Ok Tim, I will follow your suggestion ;)
I will split only the lines belonging to the same layer, unlike polygons'
avoid intersections which operate on all the layers having the option
turned on.
giovanni
Il 01/giu/2014 08:03 "Tim Sutton" <lists at linfiniti.com> ha scritto:
> Hi
> On Fri, May 30, 2014 at 11:53 PM, G. Allegri <giohappy at gmail.com> wrote:
>> I've implemented the option to break lines when a new line intersects
>> existing lines on the same layer.
>> I've added the option to the "snapping options" dialog. Having the "avoid
>> intersections" option for polygons, I've added a new column to define the
>> different meanings of the checkbox, in case it's a line layer or a polygon
>> layer. See the image:
>> http://cdn.img42.com/d77a446f9a52b9d0315c4b78cfce8141.png
>> Is it ok to add the option over there?
> Nice! Can you remove the abbreviation and change the text to say simply
> "Split intersecting lines" (using 'spilt' will be more consistent with
> other digitising tools and sounds less negative than break which sounds
> like something gets damaged).
> Regards
> Tim
>> giovanni
>> Giovanni Allegri
>> http://about.me/giovanniallegri
>> Twitter: https://twitter.com/_giohappy_
>> blog: http://blog.spaziogis.it
>> GEO+ geomatica in Italia http://bit.ly/GEOplus
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140602/c4a418ba/attachment.html>
