[Qgis-developer] Editing groups of layers / edit buffer / transactions
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Jun 3 02:50:19 PDT 2014
Hi devs
In the QGEP project (https://github.com/qgep/QGEP), we are trying to
create a waste water application module based on PostgreSQL and QGIS.
Other examples of application modules are GIS based solutions for water,
electicity, gas, ... So what I'm describing here is valid for a large
number of GIS based applications.
In an application module, there is usually a complex database schema
consisting of many tables, views, triggers, foreign keys, constraints,
sql functions. We found, that it is very difficult to do editing with
the standard QGIS tools. In QGIS, we have an isolated edit buffer per
layer. Once editing is stopped, the edits of a layer are commited to the
datasource. For normal edit tasks, this is a great thing. However with
many relations between the layers, it is almost impossile to work
without triggering a lot of constraint violations in the database. Also
adding or removing an object is usually done with sql functions, because
it means changes to a lot of tables. In QGEP, we would more like to work
within a database transaction and commit / rollback a series of changes
at once (after all, a database snapshot can be seen as an edit buffer on
database side).
A possibility to cope with such a special editing situation is to bypass
the edit buffer in QGIS and redirect all the read/write access of the
involved database providers through one connection (but only if this
mode is activated e.g. by a plugin, normally edit buffer and providers
will behave like now). I've submitted a pull request about that topic
and there was quite a long discussion about it, but without a clear
result. Therefore I'd like to discuss in a broader context (and
separated from any implementation issues) the idea of bypassing the edit
buffer (in special situations) and using a backend mechanism instead
(e.g. db transactions).
What are your opinions?
Regards,
Marco
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
