[Qgis-developer] labelling issues
Giovanni Manghi giovanni.manghi at faunalia.pt
Wed Jun 4 02:27:40 PDT 2014
Hi all,
I'm looking to confirm the following issues related to labelling:
*) when a layer has labels then when switching on/off any other layer
(with labels or not) the one with labels is always refreshed. This
does not happen if the layer does not have labels
*) data defined rotation works, but then the label "rotate tool" does
not work (does nothing)
*) if in addition it is defined the data defined position then the
data defined rotation stops to work and labels are rendered horizontal
*) if the position of a label is changed with "move label" tool then
the rotation is taken into account (just for that label) and the
"rotate tool" start to work
*) I'm not able to find what is the proper postgis datatype to be used
for data defined position of labels, I tested the one available wit
the qgis gui and then labels stop to render (is ok with shapefile
"decimal" data type).
cheers
-- G --
