> Maybe this is something related to this issue? > > https://hub.qgis.org/issues/9148 > > Because of this problem I found that using charvar in Postgis works better > than numeric fields. yes that's it, I edited the ticker to reflect the fact that affects also postgis, and that it is a regression. cheers! -- G --
