[Qgis-developer] Opinion on plugin named prepair (and possible likes)
Nathan Woodrow
madmanwoo at gmail.com
Fri Jun 6 05:24:23 PDT 2014
I'm not sure just adding it to QGIS like that is the best idea really, it's
a bit bolt on. It would be better to port the prepair C++ logic into QGIS
itself to use QGIS geometry rather then GDAL. We could then just expose the
API and wrap it in Python to expose in Processing.
- Nathan
On Fri, Jun 6, 2014 at 10:16 PM, Paolo Cavallini <cavallini at faunalia.it>
wrote:
> Il 06/06/2014 13:17, Hugo Ledoux ha scritto:
> > A windows Installer would be nice, but, Paulo, do you mean that QGIS
> would add
> > prepair? That would be tricky, since we use CGAL too. But that would be
> great.
> > The plugin should remember the path of the EXE, it does on all computers
> we've
> > tested. Report bug on the issue page with details please.
> Hi.
> Hugo, would you object in tagging the plugin as experimental for now?
> Yes, I meant to include prepair (the plugin+the exe+des) in the standalone
> installer,
> as well as making it easy to install it in other OSs.
> Are you willing to help with that?
> All the best.
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140606/5937703a/attachment.html>
