[Qgis-developer] [Qgis-user] A discussion: is qgis still affordable in Europe if it violate the Inspire directive ?
Alex Mandel
tech_dev at wildintellect.com
Sat Jun 7 13:19:11 PDT 2014
Please add your specific list of current non-compliant issue to:
http://hub.qgis.org/issues/6520
I'll add in a note about the WMS 1.3 tags specifically created for
non-standard features.
I think this issue can be resolved.
Thanks,
Alex
On 06/07/2014 01:17 PM, Alex Mandel wrote:
> On 06/07/2014 01:06 PM, Andrea Peri wrote:
>> Yes also this is possible,
>> but pay attention to use it correctly.
>> I guess it is no really simple to use (ie to define the extension).
> It looks really simple to use according to the docs. If it works and
> cascading WMS works with other WMS servers, and it passes the schema
> check I see no issue.
>> In the SLD world this was allowed and a unfortunately and worst
>> understanding of it will born a lot of incompatible dialects.
>> Also in the metadata world (iso19115) the possibility to extend the specs
>> will produce incompatibility monster.
> This exists in the html world, over time there are winners. If you don't
> care to use the extra features you are always welcome to use the base
> which is 100% compliant. The winners or some compromise variant end up
> in the next version of the spec.
>> I guess surely better and easy is put the new functions in in a distinct
>> and new kind of request.
> After reading the WMS doc I believe using the tags I mention is the
> correct way to do it. Technically the result is WMS 1.3.0 compliant.
> Clients are free to ignore the extra functions as not using them does
> not remove any required features.
> As to why fund it? If QGIS provides other value to your organization in
> some other way, total cost of operation may be lower to simply ensure
> it's compliant rather than to switch software or have to use multiple
> software.
> Thanks,
> Alex
>> Andrea.
>> 2014-06-07 21:56 GMT+02:00 Alex Mandel <tech_dev at wildintellect.com>:
>>> I just checked the WMS 1.3.0 specification document
>>> http://portal.opengeospatial.org/files/?artifact_id=14416
>>> Extended optional features are allowed. There is a specific way to
>>> include them. See section 6.9.5 "Extended capabilities and operations"
>>> <_ExtendedCapabilities> or <_ExtendedOperations>
>>> So perhaps we just need to wrap those extra options in a specific tag
>>> for them to pass schema testing.
>>> Thanks,
>>> Alex
>>> On 06/07/2014 12:35 PM, Alex Mandel wrote:
>>>> I understand the issue now. In order to be WMS 1.3 complaint you can
>>>> only use what's in the spec.
>>>> Looking at an analogy with html specs I find this limitation appalling
>>>> short-sighted. It means there can be no innovation testing new features
>>>> with the spec unless you manage to get it into the future spec. I find
>>>> it hard to comprehend that clients don't just skip tags that fail to
>>>> match a known tag. In html land its very common for some browsers to
>>>> know some non-standard tags, which are new features in testing to be
>>>> proposed or reworked into future standards. IE's policy of only adhering
>>>> to the spec and including no experimental tag support has been seen be
>>>> web designers as discouraging to any change. Why, because their is no
>>>> way to publicly test new ideas.
>>>> So from the QGIS side, in order to comply we would need to reply with
>>>> only allowed tags if a user requests WMS=1.3.0, we can reply with more
>>>> stuff like GetPrint if they don't specify that version. Or perhaps we
>>>> have to invent a 1.3.0+ variant specifically for when a user knows it's
>>>> QGIS server.
>>>> Anyone more familiar with WMS that can shed more light on the best way
>>>> to work around this issue and have both compliance and the ability to
>>>> add extra features that have no standard equivalent yet.
>>>> My point still stands, that EU agencies with this concern should be
>>>> funding compliance efforts, not removing funding for lack of compliance.
>>>> Thanks,
>>>> Alex
>>>> On 06/07/2014 12:23 PM, Andrea Peri wrote:
>>>>> Hi,
>>>>> I need to be more clear.
>>>>> My english is tremendous.
>>>>> The Interoperability mean to have a small set of operation euals on
>>> EVERY
>>>>> Server WMS.
>>>>> Equals mena same reqeust , same response.
>>>>> So when a Cleit WMS send a Request of GetCapabilities, The response
>>> should
>>>>> be the same from QGIS-server or from GeoServer or From Mapserver.
>>>>> The same response mean that every product use the same dialect the same
>>>>> tags and so on.
>>>>> The XSD OGC is the dictionary that every wms client and server should
>>> use
>>>>> to know the right language and tags.
>>>>> When the QGIS_Server response to a request GetCapbility with an XML that
>>>>> contains the GetPrint tags.
>>>>> The client wms say "hey what is this ? It is not in the XSD OGC. This
>>> mean
>>>>> your response is wrong."
>>>>> Of course there are some client wms that don0t do a validation of
>>> response,
>>>>> they HOPE that the response will be exactly as they exected.
>>>>> If this is not true. They go in crash or other bad situation.
>>>>> Again the resence of a Tag not compliant with XSD OGC will create
>>>>> incompatibility.
>>>>> Think to a client that will parse the xml response and say:
>>>>> ok the GetLegendGraphics tag is passed now there is "this well know
>>> tag".
>>>>> Instead arrive a GetPrint tags.
>>>>> The client wms become crazy.
>>>>> Of course QGIS will understand it.
>>>>> But this is because you (qgis group) manage it to work.
>>>>> But other clients don't know that tag and so they are not able to
>>> extract
>>>>> all the information from Capabilities response.
>>>>> This is a bad practice also because create artiiciosally an
>>> incopatibility
>>>>> with other products.
>>>>> Instead Inspire ask for INteroperability from every product.
>>>>> Interoperability don't mean use all the same unique product. (This is
>>> the
>>>>> microsoft philosophy)
>>>>> Interoperability mean All the product must use the same little set of
>>>>> command and the response at these command should be compatible
>>>>> (interoperable) between all of them
>>>>> Actulally this is not true for the response xml of qgis-server at a
>>>>> getcapability request.
>>>>> Hope to be better explain, now.
>>>>> Andrea.
>>>>> 2014-06-07 20:49 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>>>>>> Hi Alex,
>>>>>> The question is not the print capability.
>>>>>> The question is to LOST THE INTEROPERABILITY
>>>>>> If qgis response an xml that is not OGC complaint it is not
>>> interoperable
>>>>>> with other product.
>>>>>> As example:
>>>>>> if an public Administration will eed to do a cascading wms with the
>>> server
>>>>>> wms of another public administration.
>>>>>> The server before of all call for a GetCapability.
>>>>>> If the response has a tag proprietary. If fail.
>>>>>> This need Not Interoperable.
>>>>>> I dont say do not do a getprint.
>>>>>> I say remove tha tag GetPrint from the GetCapabilities response.
>>>>>> It is not a OGC tag and so that response is not interoperable as
>>> requested
>>>>>> from Inspire specification.
>>>>>> Regards,
>>>>>> 2014-06-07 20:36 GMT+02:00 Alex Mandel <tech_dev at wildintellect.com>:
>>>>>> On 06/07/2014 11:19 AM, Andrea Peri wrote:
>>>>>>>> Hi,
>>>>>>>> AFAIK the qgis server is not complaint with Inspire.
>>>>>>>> This beacausethe Response to GetCapabilities is not responding to the
>>>>>>>> requisite that the OGC will require for it.
>>>>>>>> Originally the qgis was simply generate an incompatible response for
>>> the
>>>>>>>> XSD of OGC.
>>>>>>>> The response is ncompatible for thre thinks:
>>>>>>>> 1) the GetCapabilities is in the wrong namespace.
>>>>>>>> This is a silly question anc could be easily resolved.
>>>>>>>> 2)
>>>>>>>> The presence of the GetStyle that is dismissed from OGC wms 1.3.0.
>>>>>>>> Please notice that the Inspire require the WMS 1.3.0 .
>>>>>>>> To resolve this the QGIS groups has copied the XSD of OGC and
>>> modifica
>>>>>>> it
>>>>>>>> to redirect to a different XSD not in the OGC site.
>>>>>>>> 3) The presence of a Proprietary tag inserted without any reference
>>> to
>>>>>>> any
>>>>>>>> standard.
>>>>>>>> The GetPrint.
>>>>>>>> This is not present in any other product.
>>>>>>>> My question is for any person of a Public Administration that plan or
>>>>>>> are
>>>>>>>> funding QGIS.
>>>>>>>> In Europe the Inspire directive will ask to promove the
>>>>>>> Interoperability.
>>>>>>>> The interoperability strategy ask that every produc that allow the
>>>>>>> inspire
>>>>>>>> directive will speak the same language using the same tags and
>>>>>>>> functionality.
>>>>>>>> The QGIS solution to add a proprietary tag and to write a own
>>> different
>>>>>>> xsd
>>>>>>>> that overlap the standard OGC xsd will create the presuppost (AFAIK)
>>> to
>>>>>>>> vilate the Inspire directive.
>>>>>>>> If this is true A Public Administration should not use the QGIS.
>>>>>>>> This is a realproblem for us that invest many fund on qgis.
>>>>>>>> So I like toknow the opinion of other public administration.
>>>>>>>> Before still fund a product that seem to violate the Inspire
>>> directive
>>>>>>>> principles.
>>>>>>>> Thx,
>>>>>>> To me the question is flipped. What needs to be funded, probably by EU
>>>>>>> agencies to ensure INSPIRE compliance of QGIS Server?
>>>>>>> It looks like you've put together the list of what needs to be fixed,
>>> so
>>>>>>> the target should be easier. I am little puzzled about not allowing
>>> for
>>>>>>> extra functions that are not in the standard. Unless the WMS has a
>>> print
>>>>>>> standard an extra print add-on doesn't break any expectations. Who
>>>>>>> knows, maybe that should be submitted as an extension to WMS.
>>>>>>> Note, this should have no effect on funding and usage of QGIS desktop.
>>>>>>> Maybe Paolo has good numbers on if EU agencies are funding Server vs
>>>>>>> Desktop features.
>>>>>>> Thanks,
>>>>>>> Alex
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Qgis-developer mailing list
