[Qgis-developer] add rasterlayer to qgsmapcanvas
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Jun 9 23:10:42 PDT 2014
From a quick look, maybe the destination CRS of the map canvas is missing.
In a code, I used:
mMapCanvas->setCrsTransformEnabled( true );
mMapCanvas->setDestinationCrs( xxx );
mMapCanvas->refresh();
http://qgis.org/api/classQgsMapCanvas.html#ab7cb4f74b2c21b77783bd1f49f5878d8
Cheers,
Denis
On 08.06.2014 12:49, Felix Schmidt wrote:
> Hello everyone, did anybody assorted my code and had an idea, where
> the problem can be located. I am so confused about the behavior of
> this plugin. The code you can also find on Github
> (https://github.com/MenschMarcus/HiBo-plugin)
> hibo.py:
> # Import the PyQt and QGIS libraries
> from PyQt4 import QtCore, QtGui
> from PyQt4.QtCore import *
> from PyQt4.QtGui import *
> from qgis.core import *
> # Initialize Qt resources from file resources.py
> import resources
> import sys
> import os
> # Import the code for the dialog
> from Ui_hibo import Ui_hibo
> class hibo:
> def __init__(self, iface):
> # Save reference to the QGIS interface
> self.iface = iface
> self.gui = Ui_hibo ()
> self.gui.setupUi()
> def connects(self):
> #self.dlg.ui.load_button.clicked.connect(self.loadImage)
> pass
> def initGui(self):
> # Create action that will start plugin configuration
> self.action = QAction(QIcon("icon.png"), "HiBo",
> self.iface.mainWindow())
> # connect the action to the run method
> QObject.connect(self.action, SIGNAL("activated()"), self.run)
> # Add toolbar button and menu item
> self.iface.addToolBarIcon(self.action)
> self.iface.addPluginToMenu("&HiBo", self.action)
> def unload(self):
> # Remove the plugin menu item and icon
> self.iface.removePluginMenu("&HiBo",self.action)
> self.iface.removeToolBarIcon(self.action)
> # run method that performs all the real work
> def run(self):
> # show the dialog
> self.gui.show()
> #print os.getcwd()
> result = self.gui.exec_()
> # See if OK was pressed
> if result == 1:
> print "test1"
> ui_hibo.py:
> #!/usr/bin/python
> # -*- coding: utf-8 -*-
> import sys
> import os
> from qgis.gui import *
> try:
> _fromUtf8 = QtCore.QString.fromUtf8
> except AttributeError:
> def _fromUtf8(s):
> return s
> try:
> _encoding = QtGui.QApplication.UnicodeUTF8
> def _translate(context, text, disambig):
> return QtGui.QApplication.translate(context, text, disambig,
> _encoding)
> return QtGui.QApplication.translate(context, text, disambig)
> class Ui_hibo(QtGui.QDialog):
> def __init__(self):
> QtGui.QDialog.__init__(self)
> self.setupUi()
> #self.connect(self.loadRaster, QtCore.SIGNAL('triggered()'),
> self.loadRasterImage)
> self.connect(self.canvasRaster, QtCore.SIGNAL('renderStarting()'),
> self.startRendering)
> self.setWindowTitle(self.tr("HiBo"))
> def setupUi(self):
> """setup for toolbar"""
> self.toolbarVector = QtGui.QToolBar('vector', self)
> self.toolbarRaster = QtGui.QToolBar('raster', self)
> self.zoominVector = QtGui.QAction(QtGui.QIcon("zoomin.png"),
> 'zoominVector', self)
> self.zoomoutVector = QtGui.QAction(QtGui.QIcon("zoomout.png"),
> 'zoomoutVector', self)
> self.moveVector = QtGui.QAction(QtGui.QIcon("move.png"),
> 'moveVector', self)
> self.loadVector = QtGui.QAction(QtGui.QIcon("load.png"),
> 'loadVector', self)
> self.zoominRaster = QtGui.QAction(QtGui.QIcon("zoomin.png"),
> 'zoominRaster', self)
> self.zoomoutRaster = QtGui.QAction(QtGui.QIcon("zoomout.png"),
> 'zoomoutRaster', self)
> self.moveRaster = QtGui.QAction(QtGui.QIcon("move.png"),
> 'moveRaster', self)
> self.loadRaster = QtGui.QAction(QtGui.QIcon("load.png"),
> 'loadRaster', self)
> self.selectRaster = QtGui.QAction(QtGui.QIcon("select.png"),
> 'selectRaster', self)
> self.toolbarVector.addAction(self.loadVector)
> self.toolbarVector.addAction(self.zoominVector)
> self.toolbarVector.addAction(self.zoomoutVector)
> self.toolbarVector.addAction(self.moveVector)
> self.toolbarRaster.addAction(self.loadRaster)
> self.toolbarRaster.addAction(self.zoominRaster)
> self.toolbarRaster.addAction(self.zoomoutRaster)
> self.toolbarRaster.addAction(self.moveRaster)
> self.toolbarRaster.addAction(self.selectRaster)
> """setup for canvas"""
> self.canvasVector = QgsMapCanvas()
> self.canvasVector.setCanvasColor(QtGui.QColor(255,255,255,255))
> self.canvasVector.enableAntiAliasing(True)
> self.canvasRaster = QgsMapCanvas()
> self.canvasRaster.setCanvasColor(QtGui.QColor(255,255,255,255))
> self.canvasRaster.enableAntiAliasing(True)
> #fileName = QFileDialog.getOpenFileName(None, "historical map",
> ".", "Image Files (*.png *.jpg *.bmp *.tiff)")
> fileName = "/home/felix/programming/HiBo-plugin/hibo/map.tif"
> fileInfo = QFileInfo(fileName)
> baseName = fileInfo.baseName()
> rlayer = QgsRasterLayer(fileName, baseName)
> if not rlayer.isValid():
> print "Layer failed to load!"
> QgsMapLayerRegistry.instance().addMapLayer(rlayer)
> self.canvasRaster.setExtent(rlayer.extent())
> self.canvasRaster.setLayerSet( [ QgsMapCanvasLayer(rlayer) ] )
> """layout"""
> vectorarea = QtGui.QWidget()
> rasterarea = QtGui.QWidget()
> layoutVector = QtGui.QVBoxLayout()
> layoutRaster = QtGui.QVBoxLayout()
> vectorarea.setLayout(layoutVector)
> rasterarea.setLayout(layoutRaster)
> layoutVector.addWidget(self.toolbarVector)
> layoutVector.addWidget(self.canvasVector)
> layoutRaster.addWidget(self.toolbarRaster)
> layoutRaster.addWidget(self.canvasRaster)
> layoutCentral = QtGui.QHBoxLayout(self)
> layoutCentral.addWidget(vectorarea)
> layoutCentral.addWidget(rasterarea)
> def retranslateUi(self):
> self.setWindowTitle(_translate("hibo", "hibo", None))
> #here it loads only in the legend of qgis main window
> """@QtCore.pyqtSlot()
> def loadRasterImage(self):
> map", ".", "Image Files (*.png *.jpg *.bmp *.tiff)")
> #self.canvasRaster.refresh()"""
> @QtCore.pyqtSlot()
> def startRendering(self):
> print "start rendering"
> Am 06.06.2014 07:40, schrieb Denis Rouzaud:
>> can you maybe show us the whole code?
>> Cheers,
>> Denis
>> On 05.06.2014 20:55, Felix Schmidt wrote:
>>> The layer is loading in the legend and shown in the main window.
>>> What do you mean, with the symbology. In front of the layer, in the
>>> legend, is a raster icon, if you mean this.
>>> I copied the code from the slot to the building of the ui. so the
>>> layer is loading in the canvas by building the gui and not by
>>> clicking in the toolbar.
>>> If I start qgis with this state of code, its starts and load load
>>> the layer, when I start the plugin the canvas is still white and
>>> when I clicked on the starting picture of qgis which is still there,
>>> the layer is shown in the canvas of the plugin.
>>> It's confusing me.
>>> Felix
>>> Am 05.06.2014 20:20, schrieb Tim Sutton:
>>>> Hi
>>>> On Fri, Jun 6, 2014 at 12:15 AM, Felix Schmidt
>>>> <felix.schmidt at uni-weimar.de <mailto:felix.schmidt at uni-weimar.de>>
>>>> wrote:
>>>> Same mistake with refresh() at the end.
>>>> Am 05.06.2014 19:11, schrieb Rouzaud Denis:
>>>> self.canvasRaster.refresh() at the end ?
>>>> On 05 Jun 2014, at 18:27, Felix Schmidt
>>>> <mailto:felix.schmidt at uni-weimar.de>> wrote:
>>>> Hello everyone,
>>>> I try to load on signal, a rasterlayer to qgsmapcanvas.
>>>> I try it like in
>>>> the pycookbook:
>>>> @QtCore.pyqtSlot()
>>>> print "slot works"
>>>> "historical map",
>>>> print rlayer.extent().yMinimum()
>>>> self.canvasRaster is defined in the gui . I search for
>>>> 8h but I dont
>>>> find a solutionen, because there are no errors.
>>>> It load the rasterlayer to the main program of qgis,
>>>> but not in my
>>>> qgsmapcanvas. it is still white.
>>>> Is the layer loaded, showing in the legend but just not visible?
>>>> Check the symbology for the layer is defined properly if this is
>>>> the case.
>>>> Regards
>>>> Tim
>>>> please help me.
>>>> Felix
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> <mailto:Qgis-developer at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Tim Sutton - QGIS Project Steering Committee Member
>>>> Please do not email me off-list with technical
>>>> support questions. Using the lists will gain
>>>> more exposure for your issues and the knowledge
>>>> surrounding your issue will be shared with all.
>>>> Irc: timlinux on #qgis at freenode.net <http://freenode.net>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140610/68e9653c/attachment-0001.html>
