[Qgis-developer] Trouble compiling QGIS on Ubuntu Server
Andreas Neumann
a.neumann at carto.net
Tue Jun 10 07:10:39 PDT 2014
I was able to solve the problems.
Seems like only environment variables set by SetEnv in
/etc/apache2/mods-enabled/env.conf are respected.
Variables set in /etc/apache2/envvars or with the FcgidInitialEnv
parameter in /etc/apache2/mods-enabled/fcgid.conf seem to be ignored.
Very strange.
My Apache does not behave like described in the documentation. The only
way to ensure that environment variables are seen by fcgid apps seems to
be SetEnv in /etc/apache2/mods-enabled/env.conf
Maybe this helps someone who migrates from 12.04 to 14.04.
Andreas
Am 10.06.2014 10:21, schrieb custard:
> On 10/06/14 16:59, Andreas Neumann wrote:
>> Hi,
>> With the self-compiled libspatialite (4.1.1) I am now able to compile
>> QGIS server. It does not work with the internal spatialite library
>> provided by QGIS and it also fails with the version provided by Ubuntu
>> 14.04 ;-(
>> Now I am running into the next issue that Apache does not find my
>> Postgis-Service definitions. Maybe the Apache 2.4 environment variables
>> have a different setup than in previous Apache / Ubuntu Server versions.n
>> Thanks for the hint - eventually I will be getting there,
>> Andreas
> I think I remember reading that there are others that were having
> problems shifting to 2.4. Does any of this thread help?
> http://lists.osgeo.org/pipermail/qgis-developer/2014-March/031333.html
> -ramon.
> Qgis-developer mailing list
