[Qgis-developer] [Qgis-user] LIZMAP ERROR PRINT - HELP!
Jürgen E. Fischer
jef at norbit.de
Wed Jun 11 01:25:36 PDT 2014
Hi Andreas,
On Wed, 11. Jun 2014 at 08:39:11 +0200, Andreas Neumann wrote:
> It is true that in some cases we need to improve to be more standards
> compliant. This is a group effort. Everybody can contribute. Removing
> GetPrint from GetCapabilities, or implementing in a standard compliant way,
> would help. We could still have it listed in GetProjectSettings.
It's disputable if the current way is not compliant.
Changing that might break clients that query the capabilities for the presense
of GetPrint if we'd applied a (less-disputable ;)) compliant prefix (ie.
GetPrint to qgis:GetPrint).
Note that this would only apply to the name of the operation element in
capabilities, the actual request wouldn't need to changed.
So it's unclear to me if there are actually any clients that would break.
At least some already use GetProjectSettings, others might just imply GetPrint
without checking GetCapabilities - both groups wouldn't be affected.
The clients that check capabilities would just need to look for qgis:GetPrint
instead or alternatively of GetPrint - and that should just be a trivial
change, when 2.4 is deployed.
Also there are probably not that many clients around that actually use
GetPrint.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS PSC member (RM) Germany IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
