[Qgis-developer] [QGIS Mapserver] addDrawingOrder changed logic in 2.4?
    Andreas Neumann
    a.neumann at carto.net
    Thu Jun 19 01:41:41 PDT 2014
Thank you Giovianni and Marco for fixing this.
I discovered the issue as well but was too busy to act or even report in
the past couple days. I did not have time to investigate the problem.
I can confirm that QGIS server and web client (both master) work fine
together again.
Thanks,
Andreas
Am 18.06.2014 15:32, schrieb G. Allegri:
> This pull request shoud fix it, but please review it in case it would break
> somethign else https://github.com/qgis/QGIS/pull/1462
> 2014-06-18 17:02 GMT+02:00 G. Allegri <giohappy at gmail.com>:
>> Thanks Marco.
>> Done in http://hub.qgis.org/issues/10625
>> In case the changed logic is only a side effect of the parsing
>> refactoring, the solution seems quite straightforwars, rolling back to
>> differentiating between embedded/not embedded layers.
>> giovanni
>> 2014-06-18 16:52 GMT+02:00 Marco Hugentobler <
>> marco.hugentobler at sourcepole.ch>:
>> Hi Giovanni
>>> Please open a blocker ticket about the layer order and assign it to me.
>>> I'll try to look at it before the release.
>>> Regards, Marco
>>> Von Samsung Galaxy Note gesendet
>>> -------- Ursprüngliche Nachricht --------
>>> Von: "G. Allegri" <giohappy at gmail.com>
>>> Datum: 18.06.2014 16:34 (GMT+01:00)
>>> An: qgis-developer <qgis-developer at lists.osgeo.org>
>>> Betreff: [Qgis-developer] [QGIS Mapserver] addDrawingOrder changed logic
>>> in 2.4?
>>> I'm investingating why QWC is giving me problems with QGIS Server 2.4.
>>> I've spot a difference between QGIS 2.2 and the master code which seems
>>> to cause problems during the GetProjectSettings response parsing.
>>> In previous versions of QGIS Server addDrawingOrder worked for project
>>> layers [1] while for embedded layers we had addDrawingOrderEmbeddedGroup
>>> [2].
>>> Now we have only addDrawingOrder which seems to work only for embedded
>>> projects.
>>> The result is that, without emdedded layers, the <LayerDrawingOrder>
>>> element will always be empty.
>>> This seems to cause some problems on the QWC side. In fact now QWC works
>>> only with GetCapabilities, while it worked both with GetCapabilities and
>>> GetProjectSettings before.
>>> Is there a reason for this change?
>>> giovanni
>>> [1]
>>> https://github.com/qgis/QGIS/blob/release-2_2/src/mapserver/qgsprojectparser.cpp#L3644
>>> [2]
>>> https://github.com/qgis/QGIS/blob/release-2_2/src/mapserver/qgsprojectparser.cpp#L4067
>>> Giovanni Allegri
>>> http://about.me/giovanniallegri
>>> Twitter: https://twitter.com/_giohappy_
>>> blog: http://blog.spaziogis.it
>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
>> Giovanni Allegri
> Qgis-developer mailing list
