[Qgis-developer] Server: symbols missing when classified with high ASCII
René-Luc Dhont
rldhont at gmail.com
Fri Jun 20 02:15:46 PDT 2014
Le 20/06/2014 11:07, Paolo Cavallini a écrit :
> Il 20/06/2014 10:51, René-Luc Dhont ha scritto:
>> Does the issue still exist ?
>> I take a look at the map application and roads are well rendering.
> Yes, the underlying issue is still there. I kind of solved for that application
> simply using an INT field, and applying labels to it.
> All the best.
It's probably due to different encoding in desktop (Latin1), server
(UTF-8) and data (Latin1)
Regards
