[Qgis-developer] QGIS 2.3 credentials problem
Martin Dobias
wonder.sk at gmail.com
Fri Jun 20 04:06:32 PDT 2014
On Thu, Jun 19, 2014 at 5:29 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Tudor,
> On Thu, 19. Jun 2014 at 13:15:51 +0300, tudor yahoo wrote:
>> Since 2.3 got out, QGIS asks the credentials for the database connection from
>> time to time (sometimes, instead of credentials box the project simply
>> freezes). Is there an option to turn this off that I didn?t notice?
> It's probably just the connection that is failing. In that case QGIS shows the
> connection error message and prompts for credentials. But the error message is
> not evaluated, so it might not be a authentication problem at all.
There was an issue with the credentials - now fixed:
http://hub.qgis.org/issues/10655
Regards
Martin
