[Qgis-developer] qgis-server will crash on a specific project
Andrea Peri aperi2007 at gmail.com
Sat Jun 21 22:29:31 PDT 2014
I do some other tests.
I take my project that give QG crash and split it in two compementary projects.
Of course I do this using qgis desktop to avoid unvolontary errors.
Testing both of them on QS there is no crash !
So:
The first plausible theory I can give is that Qgis-Server has a LIMIT
to the number of Groups or Layers it can have in a project.
A limit different (and less) than qgis desktop (osgeo4w version).
Is this a plausible theory ?
Thx,
Andrea.
2014-06-21 22:04 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> I have a qgis-server that will crash on a specific project.
> The qgis-server will run correctly with another project that seem
> almost similar (both use the SVG symbols).
> The project that crash my QG  run correctly and smootly on a qgis
> desktop (qgis-dev) on a windows system.
> The project use SVG symbols, but also the other project I test on
> QSused SVG symbol
> so I suppose the SVG engine is ok.
> Also I check t have set correctly the SVG paths.
> Also I update to the very last (about 4 hours ago) master version.
> After all this check the qgis-server still crash.
> So I try to set the logfile, but the log is always empty.
> This mean that the cgi qgis-server will crash almost immediatly.
> So I set an environment shell to run it manually and to test the cgi
> with a gdb session.
> The results are this:
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> Warning 1: Unable to find driver ECW to unload from GDAL_SKIP
> environment variable.
> Warning 1: Unable to find driver JP2ECW to unload from GDAL_SKIP
> [New Thread 0x7fffe307c700 (LWP 1844)]
> [New Thread 0x7fffe27ea700 (LWP 1845)]
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007ffff4fc06da in qHash(QString const&) ()
>    from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
> (gdb)
> The version of libQtCore.so.4 I run on the linux is 4.8.2.
> Perhaps the 4.8.2 is too old for qgis-server ?
> But another project will run without any apparent problem.
> Many thx for every hint.
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
