[Qgis-developer] QGIS Crash - Serious problem in 2x
Bernhard Ströbl bernhard.stroebl at jena.de
Wed Jun 25 02:02:57 PDT 2014
Hi Nyall,
thanks for clarification!
However I would say that even if using a projected coordinate system
(map units m) scalebars are not neccessarily accurate all over the map:
if your map covers a small area this may hold true but not if you look
at continents.
Bernhard
Am 25.06.2014 00:13, schrieb Nyall Dawson:
> On 25 June 2014 01:20, Bernhard Ströbl <bernhard.stroebl at jena.de> wrote:
>>>> It does also matter in degrees, depending on the projection. same in
>>>> meters: 1 cm on the map represents always a certain distance in
>>>> reality (though this distance varies troughout the map depending on
>>>> the projection and the area covered). If you look at the Lambert map,
>>>> you realize that the distance between two parallels (10 degrees!)
>>>> increases towards the pole, although in reality it is always (10*110km
>>>> =) 1100 km. In the WGS84 map the distance between the parallels is
>>>> constant but so is the distance between the meridians, but this is
>>>> false as the distance gets less towards the pole in reality. So a
>>>> scalebar (in m) being accurate in the middle of the map becomes less
>>>> accurate towards the edges. Hence my question on which base the
>>>> scalebar is calculated.
>>> The question absolutely makes sense but I don't know the answer :)
>> Could you check? or whom would we have to ask?
> It's calculated this way:
> If you're working in a projected coordinate system (ie, map units are metres):
> - Take the current extent of the map, calculate the width (x max - x
> min), divide this by the width on paper of the map
> If you're working in a geographic coordinate system (ie, map units are degrees):
> - Convert the width of the map (map's extent x max - x min) from
> degrees to metres, using a variant of the Haversine formula, and
> treating the current latitude as the MIDDLE LATITUDE from the map's
> extent
> - Convert this distance to a scale by dividing by the width on paper of the map
> So, yes, scalebars using m/km/miles/etc are only an approximation when
> map units are degrees, and are very inaccurate when used with maps
> covering a large area or for areas far from the equator.
> Nyall
__________ Information from ESET Mail Security, version of virus signature database 9997 (20140625) __________
The message was checked by ESET Mail Security.
http://www.eset.com
