[Qgis-developer] Access count and center point from QgsPointDisplacementRenderer
Martin Dobias
wonder.sk at gmail.com
Wed Jun 25 05:03:16 PDT 2014
On Wed, Jun 25, 2014 at 6:24 PM, Matthias Ludwig <kaotika at gmx.de> wrote:
> Hi Martin,
> I hope you will find some time to do the improvements. :)
> My wishlist would be:
> - set the tolerance fixed or in relation to the scale so it can update while
> zooming
Also on my wish list (set tolerance in pixels, not just map units).
> - ability to calculate sum(), min(), max(), avg() of numerical values of
> group members, at least the count of points in each group
Count of points is also on my wish list.
> - using the same renderer (single symbol, categorized, graduated, rule
> based) for the cluster point
Not sure what this means...
Regards
Martin
