[Qgis-developer] 2.2 project keeps crashing after load
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Wed Jun 25 07:29:00 PDT 2014
For me for the first time, when I double-clicked on the project (qgs file)
it opens qgis and immediately crashed (windows 7 64 bit OSGEO latest
nightly). I then open the project from within QGIS, it worked fine. And
double-clicking on the project also worked subsequently.
Cheers,
Saber
-----Original Message-----
[mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Jürgen E.
Fischer
Sent: 25 June 2014 15:21
To: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] 2.2 project keeps crashing after load
Hi Andreas,
On Wed, 25. Jun 2014 at 13:25:07 +0000, Andreas Neumann wrote:
> I can only reproduce the issue on Windows (Win7 64bit). It does not
> appear on Linux 64bit. Also on Windows it does not happen always, but
often.
> My project is here to download with SpatiaLite 4 as a datasource:
> http://webgis.uster.ch/temp/qgis_crashing_project.zip
Hm, anything special to do? I tried to zoom and pan - works fine for me.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS PSC member (RM) Germany IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
