[Qgis-developer] Qgis master very slow saving project & closing with several layers
    Tim Sutton
    lists at linfiniti.com
    Thu Jun 26 15:52:45 PDT 2014
Hi
On Fri, Jun 20, 2014 at 9:29 PM, kimaidou <kimaidou at gmail.com> wrote:
> Hi,
> Thans for you help, I will try to setup the problematic project and
> publish it somewhere whenever I find the time.
Also try disabling all plugins to see if it is perhaps a plugin listening
for remove layer events that is causing the slow down.
Regards
Tim
> Michael
> 2014-06-20 13:50 GMT+02:00 Denis Rouzaud <denis.rouzaud at gmail.com>:
> I have a project with ~100 layers and did not noticed such behavior.
>> Both on Ubuntu and Windows.
>> Cheers,
>> Denis
>> On 20.06.2014 13:45, Martin Dobias wrote:
>>> Hi
>>> On Fri, Jun 20, 2014 at 3:49 PM, Giovanni Manghi
>>> <giovanni.manghi at faunalia.pt> wrote:
>>>> Hi Micheal
>>>>  Could you give us the link to the issue on the hub ? I really think
>>>>> this is
>>>>> a nasty one.
>>>> I didn't filed one yet, I'm trying to understand at what point the
>>>> issue arises when adding layers.
>>> I have tried to create a project with ~120 layers from postgis and
>>> both saving project and closing QGIS are quick. Tested on linux/64bit.
>>> Maybe there is something specific to your project?
>>> Martin
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140627/06df5b49/attachment.html>
