[Qgis-developer] Renaming Save Style -> Save Properties (Vector layer dialog)
    kimaidou
    kimaidou at gmail.com
    Sat Mar  1 06:55:09 PST 2014
Hi Nathan, all,
I completely agree we should change the "Save/restore Style" into
"Save/restore properties". I also think it could be great to have a button
"save style". But the latest should not lie in the bottom of the layer
dialog, but instead in the Style tab only, to avoid confusion.
By the way, having a "save style" button could also lead to the ability of
saving/restoring more than one style for each layer (via a combo box for
the restore button), which could be great too.
Regards,
Michael
2014-03-01 15:01 GMT+01:00 Régis Haubourg <
regis.haubourg at eau-adour-garonne.fr>:
> Hi Nathan I agree with your proposal of renaming style by properties.
> Users don't understand they also inherit labels, metadata and so on when
> loading a style.
> By the way, I think some improvements can be made for reloading style use
> case. Problem occurs (maybe occured, didn't check recently) when user want
> to transfer graduated or single value style classes from one column to
> another. Copying style from another table often leads to that situation,
> where field or expression is not in target table.   I know this can be
> tricky since graduated classes are in autosync with numeric data.
> Another issue occurs when geometry type is not the same. Maybe we could
> save
> at least color when reapplying style (from point to polygon for instance).
> This was my small thread highjack ;-)
> Cheers,
> Régis
> http://osgeo-org.1560.x6.nabble.com/Renaming-Save-Style-Save-Properties-Vector-layer-dialog-tp5106749p5106775.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140301/a7af6b8a/attachment-0001.html>
